Well, let's reverse engineer this thing and figure it out.
The "legs" would only be necessary to either give clearance and/or an accurate depth/distance from either a vise, table, or tooling.
The radiused recesses would most likely be either recessed to allow for clamping, or access with a mill/drill/router.
The shelf extends beyond the legs, so that area either needs extra clearance, or to fit into a limited access area.
The surfaces are machined, so it's important that this tool is square/parallel. Or you are just that anal.
So with all of this in mind, it's pretty clear what this is for.
Jerk-ass....LMAO
Looks to me like a fixture for holding uneven scales to drill from the bottom, flat side. Mine is just a sawn-off piece of channel iron...![]()
Is it for squaring and/or making parallel with one of your many disc grinders the aforementioned uneven handle slabs?
It is for clamping the tang to for drilling the scales. Right?
where's the left one???
tricky
jm
You were posting when I was,
You are SOOOOOOO close!
