- Jun 11, 2006
Here is my new tank i got to use for my forge. it is 8" wide and around 14" long it has a handle and legs. i was wanting to do a vertical forge but i came across this tank and for 20 bucks i hade to have it. i was thinking about doing a 2 burner venturie with one layer of fiber with one more layer on the bottom of the forge to create a flore and seal up the layer seam. but my question is this. is one layer of 1" fiber going to be ok for welding temps. also what kind of doors should i put on this. i was thinking about doing a 2" hole out the back and cutting a 6" hole in the fround so that there is a 1" lip around the edge. then i would put a plate over the hole that has a smaller hole in it around 3x3 and bolt the plate onto the frount. so i can take it off to change the lineing. any help with this would be great because i realy dont know what im doing. what size burners should i use, should i make the burners or but them. and what size of burner input hole should i cut into the side. the tank seames to be between 1/8"-3/16"thick. thanks for all the help.
