- Nov 15, 2005
I started the day with lacing and truing a Harley wheel. I was so eager to start my forging that I did the wheel in record time.
I was planing to try and do some forge welding with my old new forge. I had the jets with 1/8 holes in them like on IG's site. For some reason it was sucking up gas sooo fast the hole propane tank froze, and stopped working
. (I am not kidding). In under 15min I burned 7lbs of gas. To top it off my steel wasn't getting hot enough to weld.
I then brought the orifice on my burners down to 1/16. This did tremendously help on the use of the gas, and stopped the tank from freezing up. However it just wasn't getting hot enough.
I then came to the conclusion that without extra money spent on more insulation this forge just wouldn't be able to do what I wanted it to do.
So I devised a plan to make a smaller more efficient forge. I had some left over inswool, Mortar, and some sheet steel. I robbed one of the burners off my old forge. This is what I came out with. I feel it is a lot cooler looking and a hellllllll of a lot more efficient. On top of all that is was easy to build, (if you have the materials), in only 3/4ths of a day.
Specs:
Is constructed of 4 pieces of sheet steel. THey are about 15 and 1/2 in. long and 10in high. (If I remember correctly.)
I have 1 burner made in the example of Indian George's burners. http://www.indiangeorgesknives.com/building_a_forge.html (Thanks a lot by the way your site is a huge!! help)
The blower is a 164CMF forge blower form Blacksmiths Depot http://www.blacksmithsdepot.com/Templates/.../164_CFM_Blower (Surprisingly powerful)
I purchased the inswool and refractory mortar from Darren at http://forgegallery.elliscustomknifeworks.com/ (Really nice people who know what they are talking about!!)
Here are some pics:
I welded this entire forge with that Mig.
I don't know if you can see it but that is only 1psi. I found that amazing.
Thanks for everyone who helped. You may not know you did, but you did.
I am thinking of building a door for it, but for now I am going to use fire brick. I am also going to line the bottom with 3 firebrick.
Specs:
Here are some pics:
