Well, the obvious answer is cut it in half and look!
The longer answer is you will have to do some guessing. It will depend on the wood, moisture content, temp, pressure (vac). Pine it will go through in hours. Oily wood like mesquite it won't even penetrate but a short distance in days. Get some cheap lumber-yard woods like pine, oak, walnut or cherry, scrap osage, etc that is cut into handle-sized pieces. Make 2 each. Run one set 8 hours, then slice down the middle length with your bandsaw and look at the inside. Do another set for 24-48 hours and see if there's a difference. Adjust time as necessary. If you are interested in osage, make blocks that you can render into scales when you cut. That way you can still use it there's no useless wood.
The other way, and how I did experiments, was to put them in for awhile, then remove and weigh. Back in, weigh, etc until the weight stabilzied. Then I cut them in half.
Sorry I can't tell you better than that, Phillip.
