Tai Goo
BANNED
- Apr 7, 2006
Spring Scenery in South of Yangtze River:
http://www.youtube.com/watch?v=1JlwFclmeC4&feature=related
Where's the transcendence in science?
There’s an old formulation describing the creative process: http://en.wikipedia.org/wiki/Creativity
Preparation
Incubation
Inspiration
Verification
You have a problem you want to solve. First you work at it like a dog. Think about it, try different things, fail again and again. Keep working and working. Tough problems can require years of concentration.
During that time, outside of quotidian awareness, the problem and its elements quietly steep. What actually happens during incubation is a mystery.
Inspiration gives you an answer. Out of the blue. Unanticipated by the conscious mind.
Just because it is inspiration doesn’t mean its right. You must test your results against reality. Be it by physical experiment or by trying the solution against mental maps. Does that solution solve enough of the issues you needed to solve? If not, return to step one.
The process is the same, no matter what the question. It works when creating a painting. It works improving your pole vault. It works solving a scientific question.
One famous instance of scientific inspiration was Kekule's discovery of the benzene ring. Here is his description.
"I was sitting writing on my textbook, but the work did not progress; my thoughts were elsewhere. I turned my chair to the fire and dozed. Again the atoms were gamboling before my eyes...My mental eye, rendered more acute by the repeated visions of the kind, could now distinguish larger structures of manifold conformation; long rows sometimes more closely fitted together all twining and twisting in snake-like motion. But look! What was that? One of the snakes had seized hold of its own tail, and the form whirled mockingly before my eyes. As if by a flash of lightning I awoke..." And tested the idea, and found it worked. The benzene molecule had a circular structure
The linked article includes this quote: To elaborate on one example, Einstein, after years of fruitless calculations, suddenly had the solution to the general theory of relativity revealed in a dream "like a giant die making an indelible impress, a huge map of the universe outlined itself in one clear vision."
Another example, paraphrased from memory: Isaac Singer tried and failed to design a mechanical sewing device. Finally he dreamed he was captured by cannibals. They stuck Singer in a pot. They were having him for dinner unless he could invent his sewing machine. Singer noticed that the tribal spears had holes through their blades. He woke knowing he could make his machine work if he put a hole at the front end of the needle. So the Singer Sewing Machine was born.
That time of inspiration is a spiritual experience. Creative solutions come from a source which is smarter…larger…beyond…the conscious mind. The solution is transcendent in the sense that it is outside the intellectual categories used to frame the question. It is transcendent because that source is outside of and beyond normal mental processes. It is transcendent because the seeker is touched by the unknowable numinous mystery which gives the answer.
That is the transcendence of science.
We need to remember that not all discoveries are made because someone sought to make a discovery.
Yeah, that's one way to solve a problem.
Another way is to do something just because you like the way it looks and then, quite without any focus on the problem itself, you solve another problem just because the look you liked ended up being more than a look.
I like that, but it's not normally how we are taught to think about science, or the scientific method. I think it's true though. Science isn't as pure as we've been led to believe, which goes back to the type of pseudohistory of science that is so prevalent. The process of art, science, history, philosophy etc., are all essentially the same. They involve higher functions of the brain and the spirit. Science is no different than anything else...
It's the vitue of transcendence found in every field... in humans. Some might even call it mysticism or intuition.
We're finally learning the "truth" about science... what it is, how it really works.
Not sure if those stories are true or not, but...
Great post!![]()
