I've had some time to play with my Scrapper 5 and I've read the comments in the Scrap Yard Forum. Most of the comments I've read have been very complimentary. But some have not. And the ones that have not are worthy of consideration.
One individual felt that the thumb ramp is in the wrong place. I agree with him. If you've got an S5, hold the knife in a natural position and rest your thumb on the ramp. Then notice where the ramp hits your thumb. Unless you have really small hands, you'll either have to grip the knife further back on the handle to straighten your thumb out or you'll have to bend your thumb to position it properly on the ramp. Either way, the ergonomics aren't great. His point that a ramp isn't needed in a knife the size of the Scrapper 5 also has merit. If I were to customize my S5, the first thing I would do is grind off the ramp!
Someone else mentioned that the choil is too shallow. Again, I have to agree. If you choke up on the knife and you're not careful, it would be very easy to cut yourself. Either the choil should have been cut deeper into the blade or, better yet, removed entirely.
Last but not least, someone said that the knife is blade heavy. Once again, he's right. Grip the handle naturally and then slowly release your grip. The knife will fall forward towards the tip every time.
The S5's saving graces are its sleek lines, comfortable handle, and the fact that it's constructed of SR101 . . . an alloy with an impeccable pedigree. Oher than that, I believe an argument could be made that the S5 might have profited from some design changes.
Comments?
