Yup, all my Sebenzas and Mnandis can be tightened right down with no change to the action of the blade. If your knife does stiffen up that is because the bushing is "shorter" (not larger) than the width of the blade and washers and the scales are pressing on the blade through the washers. The whole point of the bushing system is to stop that happening so if it is happening then you have "problems" of a sort. The OP also said it was not the original blade....so as they say "there's your problem right there....."
I have a Sebenza that is nearly 12 years old that can still be cranked right down with no play or stiffening of the blade action at all. That is what the Sebenza is and should be about.:thumbup:
Ok, a few things to cover that has not been mentioned or asked:
Did you do the blade swop or was it sent to CRK for reblading?
Reason: each washer, bushing is sanded and hand fitted to each sebenza. In the CRK DVD this can be seen and a SMALL bit is taken off at a time untill the action is correct.
Secondly, and I have mentioned this numerous times and can be found under searches for stiff sebenza.
The blade is stone washed, untill that stone wash becomes smooth underneath the washers, ie. It becomes like a mirror under the washers from many many openings and closings, the action can be stiff.
Just to clarify the stifness.
When tightened all the way you can't open it!
When i find the spot where it tightenes the pivot screw and the blade works smooth, it just needs a few opening and closing for the screw to get loose again!
So then, when closed, if you press with the thumb on any surface of the pivot it sticks out a bit on the oposite side!
Oh, I also forgot to mention that the lock is a bit sticky!
If I missed it somewhere I apologise, but did CRK do the reblade? Or was it a blade swap between knives?
Haze
When I handled a polished blade sebenza brand new that was SMOOTHer then any other stone washed blade in the shop. Including the Umnumzaan.
After 2 years and my Insingo getting that mirror polish it is as smooth as that polished blade at last. Naturally I formed my own conclusion.
Note: the action of the stone wash was still hydrolic and people not use to the Seb might think it is stiff compared to other knives, but it will smooth in my experience as the stone wash becomes polished.
I do think the specific knife has another issue though if we are talking about this knife being REALLy stiff and hard to open.
