- Sep 29, 2008
So as you guys have probably seen in the other thread My sebenza was sent in for warranty work on fixing the lock rock.
I got the knife back with the same amount of play in the lock as before and was quite frustrated.
That being said after experimenting with my other sebenza I have found what the true issue is. I would like to say I was 100% correct in saying the knife was not abused or flicked in any way.
How do I know this? Well I took the s30v blade out of the sebenza that had the lock rock issues and the flaked off heat treatment on the lock face. I then put the s30v blade in my s35vn sebenza handle and basically swapped the blades to see if this would get rid of the lock rock.
The results confused me for a second..... the s30v handle with the flaked off heat treatment was now rock solid with the s35vn blade in it and the s35vn handle with the s30v blade had rock lock.
This show me two very important things.
1) The most important thing it showed was that the problem did NOT in fact lay within the lock face flaking but rather the tang of the s30v blade.
2) Chris did what he thought would fix the issue because we both thought it was the lock face heat treatment when it was not.
After this I formally want to appologize for what I said in the previous threads about Chris not fixing the issues during the warranty process because he did what he and I both thought would fix it.
That being said Im kindof in between a rock and a hard place. Should I send in the knife with the rock lock and have them switch out the blade for a s35vn one with the correct tang face or should I keep the s30v blade with a tiny rock lock and let it appreciate in value?
This knife originally was aquired by me for a safe queen after refurbishing, because I knew the s30v sebenzas were getting harder to get and I knew it would appreciate in value.
I guess what Im saying is should I keep the s30v blade and have a little rock lock or send it in and lose the appreciating in value aspect but have a fully functioning and rock solid sebenza?
Thanks everyone, wolf5391
Sorry about that, I misread it initially.
