- Oct 29, 2013
This is my second hunter style based off the one that I made a few weeks back. I messed it up, I applied to much pressure with my thumb when passing it over the belt and did not realize it till it was too late, I pretty much gave up on it, stuck it in a board, drove home and went to bed with the intention of just starting a new one the next day. But I said what teh hell lets see if I can salvage it. So I decided to try some new things out, so I went to grinding the other side down at the tip as good as I can with out the blade getting to thin, then I figured what the hell I will taper the tang as well, so I ground that out, and figured while I was at it why not add a bolster. Bought some 1/4" mild steel and round stock and went at it. Then I attempted to adhere black G10 spacer to the handle, the bolster, and in between the bolster and resinwood. I was so fragile it just kept breaking on me so I scraped that and just left the spacer in between the bolster and resinwood.
Stupidly, when I epoxied the handle up I also put the pins in, and only made one pin for the resinwood so overnight even though it was clamped up the scales slid down just a tad on the front lowering below the spine about 2 mm. I noticed a few nicks on the blade spine that I did not notice before so i took the spine down some to mate up to the handles (I know stupid) and this messed up the top of the plunge on the FFG, looks horrible. The pin in the bolster is visible, I did not peen it any and on the other side there was what I guess a slight warble from the drill bit and really noticeable.
So all in all the knife is a failure but I learned a lot from the mistakes I made so in that I say it was a success.
The Cocobolo resinwood turned out nicely, need to polish it up some more though
