So, this is my second knife, and I just wanted to share. I hope this is the right place.
The handle is black walnut with red G10 spacer, three coats of stain with a sanding of 2,000 when dried followed by 2 coats of satin clear. The handle was buffed with a cotton wheel.
Blade steel is 01. I heat treated and tempered the blade myself. Afterwards, I had it tested three times for HRC and the readings all fell between 48 and 52.
The bevel was cut by hand with a file, and a home made guide. I made sure to draw file, as well. Also sanded the lower portion of the blade up to 2,000 grit, starting at 150. Plus buffing on a wheel after I finished sanding.
I used a home made metal sanding block. I think I'll try to find a small block of aluminium because the metal fatigues the fingers quickly
The larger surface of the blade was run on a belt sander at 400 grit. In retrospect I'm not sure that was a good choice on my part as the finish isn't uniform.
Blade has a 25 degree cutting angle on it and is a length of 4.75 inches.
(I've attached pictures, I think. I hope they're not too large? I was reading the forum rules and If they are I can remove them and resize.)
