yablanowitz
Platinum Member
- Apr 14, 2006
How coarse a bevel are we talking about? 50 Grit belt? Coarser? The scratches left by my DMT Extra Coarse hone can be polished out with a microbevel .005" wide.
I've come to the opinion that the whole issue of slicing performance is extremely complex. Weighing against the benefit of slicing aggression you get with a coarser edge are the drawbacks of reduced cutting performance overall -- a slice is, after all, actually part slice and part push cut -- and reduced edge life/retention. So deciding on the optimal edge finish is going to depend on a whole bunch of factors, ranging from materials to be cut and just how they're going to be cut, to properties of the steel itself, and even unknowables like how long it will be until you'll be resharpening the blade.
So bottom line ... if it works for you, and gets the job done, that probably counts for 90% of the results you can expect. Until somebody really sorts it all out, that is.![]()
How you do your edge bevel has very little to do with how a knife can cut cheese. The main grind of the knife is usually the problem and the thiner the knife the better it will cut cheese. Knives like the zing or groove help with solving surface friction problems because of the desing of the main grind, its said to provide 80% less friction and proves this fact very well when cutting things like cheese or meat.
True but scandi type knives work best at cutting wood not cheese.
I've read some material saying you could get a hair shaving edge with a 100 grit belt sander, but I don't have access to that equipment. I suspect that's more about a consistent and *thin* angle than a fine edge.
Why not just make a toothy edge like 320 or so grit, then strop? Im talking about belt sander grits / leather belt btw.
I realize this is a common practice, but I don't really understand it. A strop contains no abrasives and no sharpening power. Its purpose is to realign the edge after use (or traditionally, right before the next use).
But why not BOTH? Have you ever thought about that!
:jerkit:
Yeah the coarser the better, 50 grit belt sounds good. 0.05" is 0.13mm, which can be beaten by putting on the smooth polished edge first (my 'reverse-microbevel' technique). Then you can take the width down to something arbitrarily small.
Side note: In theory 50 grit is 0.30mm, so I'm a bit skeptical that you can get rid of the scratch pattern with a microbevel that is only 0.13mm (0.05") wide. In my experience you need a significantly wide microbevel using the standard microbevel technique. Hence my technique reverses the order with the smooth edge created first.
Now that we have established what your skill level and sharpening experience is, you might try actually reading the post you quoted.
1) I did not say I was using 50 grit for sharpening. I asked if you were.
2) I stated I was using DMT Extra coarse for setting back bevels, which is 60 micron.
3) If you are getting 0.15mm deep scratches from your 0.30mm abrasive, you are using way, way too much pressure when you sharpen (in my experience, which only spans forty-five years).
4) I said 0.005" wide microbevel, not 0.050". 0.050" is a secondary bevel, not a microbevel. I believe I may have mentioned that as well.
:jerkit:
I probably should have been more specific ... by "not polished" relief/primary bevel I meant a medium grit finish, what you get with ~200-250 grit using light pressure. So the microbevel only takes 5-7 very, very light passes on fine ceramic, so small you can barely detect that it's there with the naked eye even examing under bright light. But it sounds like you're after a much coarser finish on the relief/primary, so a much larger microbevel would be needed -- to the point it wouldn't be a "micro"-bevel at all.That's basically the same idea, except in a typical microbevel you are putting on the polished edge after the coarse one, not before. This technique here puts on the polished edge first so that you can get the coarse sides really really close to the smooth edge.
In a microbevel, you need to remove a good amount of metal to remove the scratch pattern of the coarse grind (otherwise you won't acheive a smooth edge). So you end up not being able to get the coarse sides as close as possible to the smooth edge.
Thanks, Broos. Part of what I enjoy about this hobby is that it's kind of like Hercules fighting the hydra: if you're being somewhat objective about it, you're probably raising two additional questions for every one you answer.Right on.
There is no such thing as realigning a edge, there is no teeth that bend and a steel does not make them stright again. A strop is ment to refine a already almost perfect edge. With compressed strop leather a natural abrasive is present but is very fine, too fine to be effective on a edge that has any sort of large burr. Applying abrasive compound like diamond paste or chromium oxide bring you the abrasive level you want while still keeping all the great effects of stropping on leather. Stropping on natural leather works but is best left for your barber to do, the edge is just too smooth for normal use.
The abrasives are silicatesI wonder how this works, there's no abrasives on the leather, nothing nearly hard enough to remove steel.
water only moved the rocks, the rocks rubbed themselves smooth against vegetable tanned leather that retains natural silicates which are abrasiveI wonder how this works, there's no abrasives on the leather, nothing nearly hard enough to remove steel.
Next, I will try sharpening with water. I've seen how 10 million years of water have smoothed rocks in the river.
