BURR. With VG-10 especially, on Spyderco blades, this is classic burr behavior.
I've never had much luck trying to strip them off in wood, the steel is too ductile & hangs on tenaciously, even when thin. Better to very, very gently file them away under feather-light pressure. Do this with the medium rods, and keep checking cutting performance every 2 or 3 passes as you work.
Stropping on hard-backed paper, such as paper glued to hardwood, and using some black/white compound also works well to remove burrs like these on VG-10.
David
When removing burrs with the stones how do you it? Same way as sharpening or do you go backwards or hold the blade at some kind of angle?
If using ceramics like the SM's rods, and especially on VG-10, a slightly elevated angle (wider than the sharpening angle) with very, very light edge-leading strokes gets it done. Use the FLATS of the SM's rods only, to reduce the contact pressure. Do this on the side the burr leans toward, and check & re-check cutting every couple of strokes. If in doubt about which side it's leaning to, it'll feel a bit 'sharper' on the side to which the burr is leaning, when checking with your fingertips. Patience is key; if you rush or lean into it with just a little too much pressure, it just multiplies the problems by making existing burrs bigger, or creating new ones.
David
So hold it away from the stone? instead of straight like normal?
Any you go heel to tip like normal?
