Update:
Last night went to work on the pen blade of my Queen with D2 steel. It's a Birdseye Maple Large Congress Knife (with just the sheepsfoot and pen blades) Model QN31BEM, by the way.
First I used a Sharpie to mark each edge, inserted the coarse SharpMaker rods at 30° and did 5 or so strokes on each bevel. The Sharpie was rubbed away on the shoulder of each bevel, so I knew my work was cut out for me (so to speak).
I rubber banded the DMT stone to the SM rod (inserting a piece of paper between the stone and the rod to protect the rod from the diamonds--and vice versa) and used the coarse side to stroke the blade. After a short while, it was evident that the coarse side of the DMT wasn't coarse enough, and I switched to the extra-coarse side.
The extra-coarse is supposed to be 60 micron / 220 mesh and is recommended when significant removal of material is needed for damaged edges. It also may be used to flatten conventional and water stones. The coarse diamond is supposed to be 45 micron / 325 mesh and is recommended to quickly restore a neglected edge. Size: 6" x 2" x 1/4". The coarseness is marked on each side of stone, but it is pretty obvious which is coarser.
I would say that it took me close to an hour of stoking on the extra-coarse DMT to re-bevel the edge of one side of the pen blade and raise a burr all along the other side. Re-beveling the edge of the other side took around 10 or 15 minutes. So maybe the other side was closer to 30°.
I did notice at least one chip in the edge near the tip of the blade that was not there when I started, but I am expecting that to go away once I finish with the coarse side. This was the first time I used the DMT, and the diamonds are expected to be extra rough at first. So it's quite possible that the DMT was initially the equivalent of extra-extra coarse at the outset.
If I had used the coarse SM rods, I would not be done with resetting the bevel to 30° even if I spent hours last night at the task. As I mentioned in the previous post, I have the diamond SM rods, which I am not satisfied with, and I am very glad to have purchased the DMT. The greater suface area alone of the DMT makes the work go quicker, and the extra-coarse side of the DMT is much coarser than the SM diamond rod. I suspect that even coarse side of the DMT is much coarser than the SM diamond rod.
The SM is a great tool, but using it to re-bevel edges of tough steel is like using a good knife to chop down a tree. Get an axe or a saw.
In this case, that means using diamonds or clipping banding sandpaper or emery cloth to the SM rods. Before I got the DMT stone, I preferred emery cloth. I have used both coarse sandpaper and coarse emery cloth clipped to the SM rods, and in limited experience, I have noticed that they cause some scratching above the bevel.
