Stacy,
I have a Chicago electric Flux Core Welder from Harbor Freight. Learned how to weld on YouTube. My welds do look like dog poop. I absolutely hate this welder with a passion. Has been nothing but hassles and a big piece of %^&*. I do have plans to take welding class at the vo-tech, it's just right down the street from me but even so I have to save a bit for a better machine. After that is done I will decide on Mig or Tig. That is all coming just as soon as i get my son through his driver-ed courses. Asininely expensive here.
On that first failed attempt it was clamped tight in a vise when I welded the 4 corners. Before I put the heat to it, you couldn't have slipped a babies hair in between them plates. I thought it was forge welded until I started hammering the edges of it and then that's when they popped open like you see in the pics.
I am almost positive I am not getting as hot as the average Joe forge welding. It is a home made bbq'er propane bottle forge (20 pounder). I have two inches of Kaowool in it with a hard firebrick floor on top of the kaowool. Then all of that is covered by about 1/2 an inch of Bubble Alumina Refractory Coating from hightemptools. For my burner I am using the single Gas burner from Mathewson Metals. I have a 0-60psi regulator from hightemptools also. For the doors I have two hard firebricks covering the opening in the back and two in the front. They slide apart on some small angle iron rails. I know this burner does not run as smooth as it should. From all the venturi style burners I see on youtube they are all a nice steady soft continuous roar sound. This one also makes a nice smooth roar but every so often (about every 15-20 seconds) it will make a hissing/gurgle noise for a couple seconds then go back to normal. It's much worse than that if I restrict any of the air-in at all. I have spent hours trying to adjust the gas and air mixtures, to get that hiss/gurgle to go away and as it is now is the best I can get it to perform. So based on that I don't know if I want to risk a second burner or just spend the money on a DFSW2 from Devil-Forge.
The mild steel rod I was trying to use was about the size of a 16 penny nail. I did exactly as you described, heated it up till it was soft orange, covered it in flux, then rubbed it around on the surface of the billet while in the forge. It never once tried to stick but it did start to crumble and fall apart in chunks after a minute or so. When That happened I just cranked the burner up as high as it would go and after a certain point the billet never got any lighter in color. It stayed at the same color (a really bright yellow) for about 10 minutes and that was as hot as it would get. On the youtube videos I watched they all get it almost white and have like this steam looking halo that comes off the steel. I never got that. A bright yellow was all I could get
On this new billet (round 2 today), it is forge welded. I got it hammered down to size now but one corner has delamed about 1/4 of an inch on the very end corner. Other than that it appears fine after hammering it to about 75% it's original thickness and about 20% longer than it was when i started. I got some more thickness to take off and length to add, tomorrow, so hopefully nothing else comes apart. Oh and I chopped off that delamed corner and it looks fine there too now.
More to come tomorrow. Thanks for all the help everyone has given. This site and it's community are awesome.
