My Very First Knife
You could use the arduino to send control voltage to a contactor, and have thethermocouple power run through the contactor. The arduino would just activate/deactivate your major circuit. Where I work we have 24 volt dc control power operating 700 hp electric motors using 4160 volt 3 phase power. Think of it as an electric computer controlled light switch.
That's an interesting way to put it. But then it would be just an On/Off type of circuit correct? There would be no way to modulate the power provided to the thermocouple. Unless that's not how they work anyway. I'll have to do a bit more research. It was mostly day dreaming anyway, I probably won't get around to building one for a long time, even if I do figure out the circuit.
Correct it would be on off control. I assumed you were trying to control it like an oven where the burners come on and off periodically to maintain a temperature. Let me ask my electrician i work with and see if he has any ideas for modulating the power.
Can you give me some more info on the unit?
What kind of voltage/amperage does it use.
What does it use at different temperature settings?
How does the expensive controller operate it?
The only thing i can think of off the top of my head would be some sort of rheostat or potentiometer in the circuit.
Let me say im just diving into knife making so i think i understand what the kiln process is. For example you may want 490 degrees for 2 hours and then off. On the next knife you may want 600 degrees gor 3 hours or whatever. My idea would be a rheostat which is basically a variable resistor, its just a knob you can turn to vary the resistance in a circuit. So you set your rheastat to whatever temp you want and you use the arduino as a fancy timer. Hook it up to a contactor and tell it you want it to run a 2 hour cycle.
Info on rheostats
http://www.tedss.com/rheostat/
If you wanted to get real fancy you could remove the knob on the rheostat and hook a servo motor up to it and control that with the arduino for fully automated operation but thats getting more complicated and probably approaching the same ammount of money as a store bought controller.
For sharpening those pesky recurves, get a Spyderco Sharpmaker! Great sharpness and easy to get things hair splitting sharp! Relatively inexpensive too! BTW-Great job on your first knife!
Info on rheostats
I'm just barely into knife making myself, I just thought if I stick with this it might be a neat project down the road. The software I found (which I now seem to have lost) would have the arduino acting as a programmable rheostat basically. If all the arduino was going to be doing was acting as a timer, I could probably rig up a timer to do the job cheaper. The only thing I could think of for controlling an external circuit is using an inductor to manipulate a switch/rheostat/potentiometer. I don't know if this is possible, I could ask some of my EE friends perhaps.
That Sharpmaker looks pretty good... I think I may go for it. Thanks :)
im not sure an inductor would be able to spin the rheostat, the high voltage ones are pretty stiff and often "click" into place at each resistance setting.
just had a thought, those old red lincoln welders had a very heavy duty rheostat in them. you can pick those things up very cheap.
I'm very impressed that you made a functional folder for your first attempt at knife making! I haven't gotten into folding knives yet. For my first knife I pretty much went in blind, got myself some 1/4 inch 440c stainless, and through some trial and error got something blade shaped. I cast bronze handles and put em on. Granted the steel is hard, and it hold an edge, but if I drop it I run a risk of either chopping a toe off, or just smashing most of the bones in my foot. Keep it up! Grinding was the hardest part for me to learn.
