This is a Mystery Ranch SATL assault pack. Waistbelt and yoke are size medium, which should fit anyone 5'8" to 6'4" with a waist 30" to 38".
This is not new however, it is is excellent condition. No rips, major soiling, defects, or other noticeable wear. There is a small stain on the right side external pocket.
From Mystery Ranch:
The S.A.T.L. is the standard issue assault pack across all of SOCOM and is the first pack to use our Bolster Ventilation and Stability system. This system was initially designed to increase the stability of the pack over body armor. In addition to the higher stability the system also promotes excellent airflow across the users’ back.
BASIC SPECS:
VOLUME: 3650 cu-in (60l)
WEIGHT: 4 lbs 15 oz (2.2kg)
DIMENSIONS: 22"x15"x13" (79cm x 38cm x 33cm) $375.00 shipped lower 48 only Alaska and Hawai will cost more to ship
INTENDED USE: SOCOM Assault Ruck
From Mystery Ranch:
BASIC SPECS:
