Nail Nick advice
What do you guys recommend for the best method in creating a nail nick? For years I have been using my dremel to gouge an embarrassingly amateur looking nail nick. Any insights are greatly appreciated.
SS
The only method I've heard of is to use the edge of a dovetail mill in a milling machine or drill press with a cross slide.
-d
I like a fly cutter. You can get a small one (1 1/8" head) from MSC fairly cheap. The small ones use 1/4" lathe bits which you can shape as needed. Also, easy to adjust the curring radius by moving the bit in or out. The only drawback is that you really need a milling machine to get good results.
jim
