Recommendation? Name and manufacturer of this knife
Not sure if this is the correct category for this :)
So I was around looking for a nice bowie knife, and I stumbled upon this:
Now I am more or less completely unknowledgeable on knives, and the website barely provides any information on this. [REMOVED WEBSITE LINK]
Here's the info they provide:
Code:
Damascus Bowie
·         Greutate (weight): 705 g
·         Lungime totală (total length): 401 mm
·         Lungimea lamei (blade length): 260 mm
·         Tipul de oțel (steel type): Damascus
·         Duritate (hardness): 58 HRC
·         Material Mâner (handle material): din piele (leather)
·         Teaca (sheath):  din piele (leather)
Doesn't say what kind of steel they use, or the manufacturer. I'm wondering if anybody here knows the exact model this knife is.
Thanks!
But I'm not trying to sell it, I wanna see if anybody knows what model this is, so I can get more info on it.
EDIT: there I removed all mentions of the price :) I just need the actual name so I can get some info on it.
Looks like a Pakistani damascus knife to me. They always claim that they are made in Canada or the US or Germany etc.
With no manufacturer or maker's mark stamped on the blade I would say it isn't worth the price.
Not a bad looking knife, but I would look elsewhere.
As a site that sells knives, (I recommend removing the link as they're not a dealer here) it would or should have the manufacturer or makers name and likely the steel listed too.
Since they don't, it's likely a cheap Pakistani made knife that is mass produced and sold wholesale en masse. Many "makers" or sites buy a bunch and sometimes put their own branding on to dupe buyers in thinking they are hand made by them.
Check out our makers forum here. Plenty of nice knives in that price range by people that respect and honor their craft. Even some from across the pond.
If you really like the design, I’d have someone make one for you so there’s not an “unknown factor”
These show up on Ebay sometimes, they are a Pakistani copy of the Down Under Knives Outback Bowie, that was reportedly made in China. All are based on the Bowring knife used in Crocodile Dundee.
The Bowring knife is based on the Puma knives bowie and the older Remington knives.
Edit - Google search "DM1204 Damascus Steel Bowie Knife" for the knife in the original post.
The Cold Steel is 100x better then what you originally showed.
Check and see if Condor Tool and Knife is available from a website that delivers to you. Condor makes a few bowie types knives and they should be less expensive then the Cold Steel if you are on a budget.
Like others have said, a carbon steel blade requires a little bit of care but nothing too drastic.
Wipe a little oil on it and you should be good. I tried using a vinegar patina on some of my 1095 knives with good results. I still keep them oiled well, but it definitely helps with the rust issue.
It may well be Pakistani, but the info sheet is a a Romance language, although not one I can readily identify. Portuguese? Romanian? Ladino?
Hmmmm.
I noticed that the snap on the sheath says "Rite Edge", so I plugged that into a search. This... may not be just another $12 Pakstani pot-metal lookalike.
Apparently, SZCO started an initiative to help war veterans. The effort is based out of Wyoming, and the article I found says that they (the veterans) "hand craft and assemble each custom piece".
This doesn't explain how much "hand crafting" goes into these knives. The blades themselves could still be mystery steel.
It doesn't lay out how much these veterans are paid, or much of anything else, really.
So, I would say:
1) It's not just another flea-market special
2) Some effort is being made to do good with these knives
3) We don't know exactly how sincere that effort is
