Name that microstructure
I am in the process of working on a few projects that involve better metallography that what I have been doing. I have been using the microscopes for a while, but I only recently got a digital camera interface that allows me to produce some quality images (I am kind of excited about that). We have had some fun quizes on metallurgy terms before, but I thought it would be fun to see if we can get better aquainted with the structures we are always talking about, to see what is on the inside of our steel. These are all images taken off from my Olympus trinocular microscope using a Cannon A95. The steel is cross sections of 10mm x 10mm Admiral 1095 in various conditions of heat treatment. Can you guess the microstructure or what the image may be telling you? (mete- no fair giving hints). For fun, I will give hints before providing the answers, although the correct answers are completely insignificant to the things we can learn and discuss from the images.
#1
#2
#3
#4
#5
#6
1st hint: #1 is not a closeup of a giraffe, although it really looks like it :)
Without cheeting and looking in my books I believe 1 is pearlite and 5 is Martinsite.
Seth
I will cheet and check my books when I get home ; )
I would agree with Seth -- I think 5 is martinsite.
Edited to add -- is number 2 austenite? It looks cubic. :confused:
(I want a microscope now. :D )
Kevin - are the images all the same magnification?
Ok here are my guesses... :foot:
1) Fine pearlite.
2) Coarse pearlite. I'm looking at those clumps with fine lines and thinking lamellar anneal.
3) An inclusion of some kind, otherwise looks pretty similar to #1.
4) No idea. What are those light, jagged shapes near the bottom?
5) Martensite.
6) Martensite with some fine pearlite left. Since it's 1095, maybe from a quench that wasn't fast enough to miss the pearlite nose on the TTT.
Just for clarification, Martensite, Pearlite, Austenite and Bainite are not structures, they are phases in the FeC system.
If the magnification of 1-3 is the same, it appears that 1 shows formation of sub-grains, 2 is a fully annealed (chemically) granoblastic texture, 3 possibly early annealed texture with the 120° intersections formed.
4 looks like a much higher magnification of strain-induced sub-grain boundary migration by Creep. The bulging flame like structures should be in the <2 micron range.
5 and 6 is a guess? Bainite overgrowth wiping out the granoblastic texture.
#1 looks like Cementite?
the rest you got me.
thanks
Zoo
They all look like food thats sat in a refrigerator with the power off for several days. Don't eat it. :D
Bill
Danbo said:
Kevin, I think you have too much time on your hands! :p ;) :D
With the Ashokan seminar only 1 week away, You can be certain that I really don't have :( . But the images were there and ready so I thought, what the heck, folks got to be interested in what is inside of those blades.
Oh no, you aren't going to make me do math are you :( ? Actually according to the objectives used #1 is 100X, #2 is 400X, #3 is 100X, #4 is 400X, #5 is 400X and #6 is 400X... but I use my cameras zoom and I have done some work with each in Photoshop so I am giving approximates and would have to work some numbers to give the precise magnification. Sorry I should have included that to begin with.
Bill
I like your conclusion the best. Steel driver actually got in the neighborhood of some of my thinking. Since the images are my own I have no text to point to for right or wrong, and I would be more than happy to have folks point out some things that I have overlooked. But I do have the advantage of having done the heat treatments to get the effects I was looking for so…
Hints:
1. is slow cooled particularly in a certain range, and it is 1095…
2. is the same as 1
3. is the edge of the same piece that was heated in an uncontrolled atmosphere, and it is 1095…
4. is the edge of the same piece
5. is quenched in water
6. is the edge of the same piece in 5 that was heated in an uncontrolled atmosphere.
As for the point of whether these phases can be referred to as “microstructure”, that is playing with semantics in my opinion. I have shelves full of books that consistently refer to bainitic, pearlitic, or martensitic microstructures when discussing metallography, but I will also defer to a more common resource, Websters Dictionary- “ microstructure: the microscopic structure of a material.” Forgive me if I stick with my sources as I think we may be over-thinking this just a bit.
Thanks for posting the pictures it is nice to see what the names look like.
Just how do you look at it, cut and polish the surface? or snap the blade and zoom in?
Do you have a wide shot shot of your microscope set up? It sounds very intersting.
Snaping the steel and looking at it is a good way for most of us to get an approximate idea of grain size, since the most common way for hardened steel to break is by cracking around the grains in the grain boundaries (intergranular separation). But for anything greater than 60X under the microscope this is a problem because at higher magnifications the focal points become too tight, so you would only be able to get one micro-thin level into focus while everything above or below that would be blurry. For microscope work you need a perfectly flat and level surface.
My pictures need a lot of improvement yet, since I do not have a press to accurately level the work (and inverted scope would be nice as well ;) ), and my polishing equipment is still limited (you can still see plenty of scratches that shouldn't be there).
To accurately determine grain size, and the quality of the other features we are observing, requires much more effort than what most are aware of. I often see folks dipping blades or steel in ferric chloride and claiming they are observing “grain”, this is false. What they are observing is the transition zones from one microstructure (phase) to another. Tempered martensite etches very differently from fine pearlite, which etches differently from course pearlite or spheroidal carbides. All you are observing at that level are the shades of gray produces by the different rates of etching, and the only “grain” you can readily observe is the fibrous anisotropic flow lines of the steel if it has been heavily cold worked or is particularly loaded with inclusions (e.g. wrought iron).
To produce the real deal you need to cut your steel into cross section with no heat at all (water cooled) since heat would change things in there. Then I rough polish the surface to 600 grit on a belt (keeping it cool), and then finish polishing on 800x, 1200x, 2000x, 4000x, 6000x. Next you do need to etch to bring out the structures, but ferric chloride, while great for damascus, really sucks at revealing microstructure. I currently use a nital etchant that is 95% alcohol and 5% nitric acid. It only takes a several seconds to darken the surface and reveal the microstructure and different features can be highlighted depending upon the time in the etch. Then the work piece is mounted on a slide with some modeling clay, this hold things in place but also lets you level the piece, and put under the microscope.
As you can see, if you really want to look at this stuff you have to work at it, and a quick dip in FeCl doesn’t show much. My digital camera has a USB connection into my computer so that I can down load direct, but more importantly I can do all my shooting remotely without vibrating the microscope assembly. I am now working on a way to accurately determine actual grain size using Adobe Photoshop as soon as the image is on my screen (image layers are quite handy).
I have pictures of my scopes on my website at this page: http://www.cashenblades.com/Info/lab/lab.html
But it doesn’t show the camera mounted on the trinoc, since I needed it to take the photo :o
As you can see Reg, as per our discussion in another thread, it is only common sense for most knifemakers to use what is available and works for them, I will readily admit that the levels I have gone to are ludicrous to anyone who is not neurotically off the deep end about the metallurgical end of things. But if I get get information from it, I might as well share it to make some of my efforts worth while.
Apologies- I just noticed that you cannot see the images on my page with mozilla unless you click them individually. I need to look into this.
no pics for me either.....Internet Explorer 6x
very interesting discussion, Kevin.
In thinsection lab preparation of polished sections for metallic ore microscopy, most use horizontal disk type polishers and take the surfaces down to .2-.3 micron diamond paste. The same polish is used for electron microscopy and for microprobe samples. I am not sure what the grit rating of that is-if the grit to micron relationship is linear, .2 micron would be ~90,000grit. You have to get all the scratches out to distinguish sub-grain boundaries, use a nitric etch, then use crossed nichols (polarizing filters) to get best view of phase relations.
It has been a while since I was involved in doing metallic ore microscopy.
Phases are the particular arrangement of the crystal lattices. In the language of materials, microstructure refers to the deformation mechanism (strain) that accomplishes the phase changes in question. Calling the grains microstructures is incorrect, just as is calling strain accumulations stress is in the material. You may call it semantics, but the language of the science is clear because of precise definitions.
It can be noted that I said “I” polish in the steps mentioned above, and I also readily admitted that my polishing leaves much to be desired. The use of terms still remains a matter of semantics for this particular discussion, which was supposed to be a fun look at the inside of steel. Can we agree on these phases being constituents of microstructure? If not, then we must agree to disagree, since that would render at least ¾ of the pages of “Principles of Heat Treatment” by Grossman and Bain incorrect, many of the discussions of micrographs in “Principles of Heat Treatment” by Krauss incorrect, and the following from “Fundamentals of Physical Metallurgy” by John Verhoeven, a bit confusing:
“The microstructure of an alloy is described by identification of the types of phases present and description of their shape and size distributions.” Pg.33
I am going to stop at three of the books I have handy, because I have some spare time to chat about the micrographs presented, but I do need to tend to some heat treating and do not have the time to spare on pettiness that is irrelevant to this thread. There may be specific meanings and definitions in various fields, and we could be dealing with two entirely different word applications and definitions. I am not sure how things are handled in geology and the study of ores (that is not my area of interest) but overwhelming evidence would suggest that these terms are acceptable in metallurgical imaging.
Now, to be honest I would much rather talk about the pretty pictures instead of fruitless debating until we start looking for typos, spelling, or punctuation errors as well (under which circumstances I would be entirely screwed).
Those that forge should be able to indentify #4 and be aware of it's consequences.It shouldn't be a mystery.
