Names for common grinding errors?
averageguy
BANNED
Are there names for common grinding errors? For example a blade where the primary grind has been more deeply ground on one side and more shallow ground on the other - leaving the edge slightly off center. And, often related, the plunge line extending past the spine - so to speak - rather than ending at or slightly below the spine resulting in an effectively thinner spine than the stock from which it is ground.
Names and descriptions of other errors?
I call that error 'scrap'.:eek: ;)
I call that a right (or left) handed knife.
A special purpose blade.:D :D :D :D :D
Doesn't Spark have rules against saying those words here:rolleyes: Seriously though, I'd say terms like uneven,off center, and too high/low are some common terms most makers understand. I use "digs" when a belt digs in on a grind because I've ridden the edge of the platen too much.
i don't have any idea what you guys are referring too? none of that stuff has ever happened to me!:D
Knifemakers don't make mistakes. They make smaller knives :)
Well, I call the ones where one grind is deeper on one side than the other 'another trip to the grinder'. And the one where the grind goes through the spine a 'blowout'. On the other hand, the extra grinding caused by a blowout can be referred to as 'a well tapered blade'. He he. If I blow out one side I go ahead and blow out the other just to keep it balanced. And when a double blowout happens I normally lay the knife down on my workbench and back slowly out of the shop and do a dissapearing act for a while. None of that happens very often but I'm sure we all have those days where our time would be better spent weeding the garden or working on a shotrod in the yard. :D
