- Dec 19, 2002
Nano-Oil by StClaire, Weight 85 (Heavy)
Suggested Retail: $18.00 Our Price: $15.95 You Save: $2.05
http://www.knifeworks.com/nano-oilbystclaireweight85heavy.aspx#.VD5_YhstDIU
Use the 85 weight on all Rapid Firearms if you favor a thicker lubricant or as a base before applying grease ex. M14 AR-15 Smooth action is instantly noticeable & guaranteed on all Firearms and Knives after applying only a few drops to all moving parts including the sear and bullet ramp.
At under 0.090 micron in size, the active molecules in Nano-Oil by StClaire are called Nano-Bearings they truly are within the nano scale technology (the width of human hair is between 50 to 100 microns) (1 micron = 1000 nanometers)
Imagine 50 million Nano-Bearings per square millimeters of contact surface on metal to metal all doing their job of substantially reducing friction while keeping equipment cooler. The Nano-Bearing molecules are magnetically induced (really negatively charged) to adhere to microscopic crevices and actually penetrate metals, providing a very - low friction - dynamic contact.
Nano-Oil by StClaire contains NONE of the following:
Silicone
PTFE resins
Graphite
Molybdenum disulfide known as Moly
Teflon
Copper
Lead
Silver
Absolutely NO Metals or harmful Solvents
Manufactured goods, Nano-Oil by StClaire can be incorporated as part of a finished product, specially valuable to items with life time warranties such as multi tools & folding knives.
Suitable for all guns, rifles, flashlight threads (anti galling), Knives, fishing reels, locks, hinges, Bicycles: bearings, cables, chains, sprockets & derailleur, motorcycle forks (will also reduce pitting of chromes), electric motors bushings, commutator/brushes assemblies, cam driven equipments, model railroads
all metal to metal dynamic contacts will benefit from Nano-Oil's usage
The NanoLube formulations are compatible with most existing lubricants on the market today both synthetic and mineral. The Nano-Bearings concentration level is such that adding a few drops to a common lubricant will improve dramatically its anti friction qualities.
Nano-Oil by StClaire is used by Swat Team Members, Sheriff's Departments & Military Personnel in Iraq where micro sand also known as moon dust is creating enormous problems.
Silicone
PTFE resins
Graphite
Teflon
Copper
Lead
Silver
