National Knife Day Flash Sales!
gpknives
Dealer / Materials Provider
Feedback: +4 / =0 / -0
Happy National Knife Day! We'll be celebrating all day with flash sales so stay tuned ;)
Little brother to the Domino, the newest flipper to join the family is theSpyderco Dice.
A rock solid tumbled titanium frame lock with steel insert and a glass woven carbon fiber laminate form the foundation of this little beast.The Dice features smooth flipping action thanks to specially designed ball bearing washers. The Eric Glesser-designed CTS-XHP Carpenter stainless steel blade is flat ground and satin finished, perfect for edc use.
Spyderco is rolling 7s with the Dice and for 2 hours only (and while supplies last) you can pick one up for $151.95, that's over 50% off retail!
The first Spyderco collaboration with Brad Southard as well as the first of their flippers is the
Spyderco Southard.
The Southard Folder has an up-swept blade of stonewashed CTS-204P, which also features a flipper, captive ball-bearing pivot system, and 0.43 inch Spyder Hole. The front side of the handle features a skeletonized titanium liner covered by textured brown G10 for a comfortable and reliable grip. The back of the handle is comprised of the RIL (Reeve Integral Lock) mechanism formed from a full slab of titanium which locks the blade solidly in place.
These guys are on a flash sale for 4 hours only and while supplies last we are offering the Original (stonewashed/brown) and the Blacked Out Southard for $229.95 and $239.95 respectively. Get 'em while they last!
The Kershaw Cryo II Flipper is a larger version of the Rick Hinderer designed Cryo built in pure steel from top to bottom. This SpeedSafe assisted opener features matte gray titanium carbo-nitride (TiCN) coating, three times as hard as chrome, for superior toughness and scratch resistance. Other features include an integral flipper and studs for opening, black hardware, frame lock with lockbar stabilizer and four-way deep-carry pocket clip.
For one hour only (while supplies last) pick one up for $29.95!
KaBar KBD Master Series and Snody Knife Designs present: The KaBar Snake Charmer with CPM-S35VN stainless steel. The hollow ground blade has a tumbled polished finish and custom maker Mike Snody's logo on the front. Each Snake Charmer includes a lime green ringed hard plastic sheath, 550 paracord and custom-designed Schmuckatelli pewter bead with Snody "S" logo. Brand new direct from KaBar Knives. Made in USA!
For one hour only pick one up for $59.95!
Want a solid neck knife with lots of carry options that you will be able to find when you set it down. Meet the Venom Green ESEE Izula. The Izula is made from solid monolithic 1095
steel that has been skeletonized for lightweight long-term carry and powder coated for corrosion resistance. It is carried in a lightweight injection molded plastic sheath which
allows for inverted carry if preferred. The complete kit includes: ambidextrous sheath, paracord, split rings, ferro fire starting rod, emergency whistle, snap hook, clip plate and hardware.
For one hour(and while supplies last) you can pick up the Venom Green Izula with kit for $50.95, over 50% retail!
The Kabar Becker BK24 D'Eskabar neck knife, a Becker Knife & Tool and ESEE collaboration, features stonewashed, high quality D2 tool steel construction. The design features the handle configuration of the ESEE Izula and the blade configuration of the Becker Necker. Kydex sheath and 550 nylon neck cord included. Made in USA!
For one hour only (while supplies last) pick one up for $41.95!
The DPx Gear HEAT (Hostile Environment At-Hand Tool) Titanium frame lock folder with OD Green G10 is a smaller version of the popular HEST model. The black coated D2 tool steel blade may be smaller (2.50"), but is just as thick as its HEST counterpart (convenient for locations with length restrictions). The two-piece handle is built with a stonewashed Titanium frame lock side and textured olive drab G10 front with open barrel spacer construction. This little tank also features a deep carry tip-up clip with glass breaker point, dual thumb studs and the familiar bottle opener notch on the blade's spine. Manufactured in Italy by LionSTEEL.
For one hour only (while supplies last) pick one up for $119.95! At this price they won't last long.
