I sharpen everything up to 0.25 micron and never have an issue keeping an edge on M4 at that level of polish and it easily cuts through plastic banding and zip ties like a lightsaber, perhaps you aren't completely deburring the edge.I agree, and I actually keep isopropyl next to me at work with a rag. I make sure I keep it clean. Some plastic straps are really thin, almost feel like the are perferatted, and it's no issue. Some are extremely thick and require a lot of force. Those are the straps that kill the knife, plus all the dirt, and metal shavings from the boxes as I have to break them down. It could be my sharpening, I could be going to find of an edge. I have a KME and I go through the diamond stones up to 1500 grit. Then 9 micro diamond tape, 6 micron diamond tape. The 4 micron diamond compound leather strop, 1.5 diamond compound leather strop. Then free hand 1 micron and .5 micron diamond compound leather strop. I may just stop at 1500 and just use the 1 micron and see it maybe not as fine of an edge holds up better.
You might be correct, but to be fair it sounds like an issue of edge retention cutting banding etc. over and over for a working day. If it's the same stuff I've had to cut, then almost any steel will be pretty dull by the end of the day.I sharpen everything up to 0.25 micron and never have an issue keeping an edge on M4 at that level of polish and it easily cuts through plastic banding and zip ties like a lightsaber, perhaps you aren't completely deburring the edge.
True, heavy cutting of hard, abrasive material with who knows what dirt or impurities will dull any edge, even with something like k390 or 10v I've managed to wreck a fresh edge in a single day from cutting those kinds of things on more than one occasion.You might be correct, but to be fair it sounds like an issue of edge retention cutting banding etc. over and over for a working day. If it's the same stuff I've had to cut, then almost any steel will be pretty dull by the end of the day.
