- Sep 4, 2004
As you've emphasized many times, cross section is what matters, and once you recognize this it becomes very straight-forward.Cliff Stamp said:This is actually a really simple geometry issue, take the three apex points of a isosceles triangle. When connected by straight lines they enclose an given area, when connected by convex lines they enclose a greater area which has no maximum, when enclosed by concave lines they enclose a smaller area which has no minimum. Of course either of the curved geometries can be approximated by multiple straight lines with the differences between them going to zero as the number of lines increases, but there is no practical difference in general with even 2-3 straight lines.
This implies that the use of such geometries should be fairly straight forward. The reason that it is not is because in general north american knives are vastly overbuilt for what they are designed to do and when they are modified to remove steel, by whichever way the user decides, this curvature gets associated with the change in performance. This is really silly and you don't see it elsewhere....
I noticed hardheart and AG Russell discussing thin blades in that seemingly perpetual 13C26 thread on the general forum, I suspect the overuse and misuse of thick stock and overbuilt blades has contributed to the myths surrounding convex grinds and edges: so many blades are so far from optimal, any relief added improves performance. As Russell points out few seem to be interested in thin blades .... that says a lot IMO about how widespread this kind of misunderstanding really is.
Absolutely. And even if you decide to run an edge or profile more obtusely due to other uses a knife may see, IMO it's almost a necessary step in evaluating a knife to reprofile to the point where any weakness - rolling, chipping, carbide pull-out, etc. - begins to show. In the end the objective is to choose an edge and profile that cuts with the least required force for the durability and toughness required by the work to be done.A productive discussion of the grinds centers on one question - what is the force responce of the material to being cut.
If you gave Mr. Miagi a tactical folder I think all he would find it suitable for is digging in the garden.That sounds like knife design by Mr. Miagi.
