Natural Gas Forge?
Hello Gentlemen, Phil is absolutely correct. Those posts from my web site are correct as well. I just run a tee off my garage furnace which is a 1" NG pipe. It's running about 1/4 PSI. Don't use any oriface restriction other than a 3/8" ball valve. I easily get 2400F degrees with this set up. Take a look at the links Phil has posted above. I've heard many people say this will not work but I can tell you it works fantastic. Keep in mind I live at sea level so you higher altitude folks may need to experiment a bit. Shoot me a message if you have any questions.
Eric
A photo would be greatly appreciated.
Here are some pictures.
This is the orfice tube, about a 1/2" hole
Gas Control ball valve
Thanks for posting Eric.
Phil,
What I was saying is that NG won't run a venturi, and on a blown forge, it needs a supply line bigger than 3/4". Any restriction will drop the flow too low. Notice that Eric had to change all things to have full size piping and a 3/8" ball valve.
Phil,
I know this is a very old thread and maybe I should create a new one, but I was wondering if anyone has ever tried using a G-TEC natural gas booster -- such as G-TEC TB-15 or bigger? I wouldn't be interested in using a venturi type burner but a ribbon burner instead. I know the torch boosters aren't cheap by any means, but if they would work for my purpose then I would purchase one. I would want my forge to get up to 3,000 degrees. I would think these boosters would be pretty safe to use as you wouldn't have to worry about wiring PID's for safety shutoff and such for power failure.
Greg
Welcome Greg. I'll leave this thread open, as the previous info is still valid.
#1 - A safety solenoid (not PID) is a very wise thing. Stuff happens in a shop, power fails, breakers get blown. You want the gas to shut off immediately when this happens.
I have never heard of a forge running on a torch booster. I don't think they will work, because the volume they deliver is far below what a forge runs at. The TB-15 is for 15,000 BTU.
Forges run at 50,000 to 200,000 BTU.
I don't know why you need 3000°F in a forge unless it is a melting forge for wootz. 2400-2500°F is plenty hot enough for damascus and most all normal knife tasks. The goal in a good forge is to get the entire liner evenly heated to a desired temperature, not how hot the flame is. This is where a PID controller is nice.
Hello Stacy,
Thank you for your response. Yes, besides damascus welding, I would like to be able to melt metals up to steel. 3,000 degrees might still be a little overkill but eh --why not lol.
Thanks,
Greg
