Well I almost got a trip to the emergency room last night courtesy of my second complete blade getting thrown back at me. I have a serious question st the end of all this, so bear with me.
First, I have cheap equipment. When I started I both didn't know better and couldn't afford more. I still can't afford better, but I'm working on that. I do most of my work by hand with files and paper anyway. I don't think that was the cause of this, but you be the judge.
The knife was basically complete, buffed out, and ready to sharpen. Since I had a good half millimeter of flat edge, I was using a worn 320 grit belt (the finest I have, a Norton Al-oxide 4x36) to do the bulk of the edge profiling. I was using very light cuts and going back and forth to keep the bevels even and the heat down. In order to see, and in keeping with the oft repeated advice, I was grinding it edge up. Apparently the edge caught the seam of the belt.
http://i13.photobucket.com/albums/a297/cdhcmh/Knives/P8200067_cropped.jpg
http://i13.photobucket.com/albums/a297/cdhcmh/Knives/P8200069_cropped.jpg
http://i13.photobucket.com/albums/a297/cdhcmh/Knives/P8200068_cropped.jpg
The knife was thrown down and deflected slightly off the work rest. It happened waaay too fast to see it's path, but it came to rest right beside my right foot. It did not hit me, but with the speed and force it was ripped out of my hand I have no doubt that if it had I would be hurting today. The tip is damaged, but it is salvageable. Dang this knife has been full of 'learning opportunities'.
Now my question is about the origin of this incident. Should the advice to grind edge up have the disclaimer: "...except when putting the final edge into a blade," or is this a case of a worn belt being pushed too far?
