Codger_64
Moderator
- Oct 8, 2004
It is hard to judge the tilt of the ground from the pictures, but what about setting the shelter to one side of the rock outcrop or the other and laying cross slope with a stone "curb" on the downhill side? You could make a short stone wall on the far side of your fire and still get the heat sink/reflector effect.
I have heated a mil-surp poncho tipi shelter with several candles before, but I had a swept floor without debris and set stones around them as a guard so I wouldn't roll into them. I managed to get a 40 degrees temperature gain in there, put it above freezing and no wind inside.
Also, consider a diamond set to your tarp rather than the pup tent set. It sheds wind better and gives a bigger face to gather heat. You can play with different setups in your back yard to see what is possible and what works best for you.
Again, kudos for keeping after it.
