It depends on what you mean. Tactical folders can be 1) tactical knives than fold or 2) the market term for semi-switchblades (AKA a manual automatic knife
). I have seen many tac folders that were NOT tactical.
The market term "tactical folders" are also called "clip knives" in some circles (I prefer that term but...) and has three qualifying characteristics.
1) It must a locking type folder
2) Have one hand opening capability
3) Have a pocket/ carry clip
There are knives marketed as tactical folders that have only two of the above, but that is just laziness on the part of certain marketing dorks (did say dork? Im sorry, I meant penis
Many of the features our fellow forumites suggest are not needed in a tactical folder, but are needed in a GOOD knife. For example:
1- A comfortable, secure handle;
2 - Reliable locking mechanism;
3- Blade built robustly
A tactical folder can be without #1, but will be a BAD KNIFE.
A tactical folder can be without #2, but will be a BAD FOLDER (unless it is suppose to be a slip-joint)
A tactical folder can be without a tempered blade that will bend like a wet noodle, but then it will be a PIECE OF $***!
As far a tactical knife is concerned; I have found three possible definitions of tactical as it relates to knives.
1) Euphemism for Combat Knife. Many people do not understand that combat knives are working knives that can be used for fighting. Instead, they are seen as murder weapons. So if we call them combat knives they will be made illegal. Can also be read as Self-Defense Only combat knife.
2) Euphemism for Always Ready. A knife that is readily available. Read: quick access. This is particularly important with folders. Once I lent my knife to a co-worker who then lost it. He later found it at the bottom of his pocket. I then told him that the reason for the clip is so you can put it ON TOP of ones pocket. The clip also helps keep the knife where one last put it. No very applicable to fixed blades unless it has a quick draw sheath. But that would be a tactical sheath for a combat knife
Loosely interpreted, tactical can be any knife you have with you. (Making it a useless adjective)
3) Any knife that can save a life. (My apologies to Mr. Randall) Be it building a shelter in the jungle, cutting someone from a seatbelt, of fending off a mugger. Since I can cut myself out of a jammed seatbelt with a paring knife, again it is a useless adjective.
Rant mode off. Hell, I never meant to turn it on, but I got BITTER somehow.
