Before getting a bandsaw, I used 8" metal cut off blades that are used in Skill saws. I just put them on my bench grinder. You a cut series of slots to your scribe lines, about 1/8" or a tad more apart, then come back and cut the created tabs out with angled cuts. It's nasty work, but doesn't take very long to do. Just don't side load these blades. I found that the Ace Hardware house brand were the toughest, and lasted longer.
Just a thought on your dremmel....It may just be the brushes on the side of the motor need to be replaced. Most places that carry dremmel bits and such should have the brushes. About a $4.- fix.
Mace
I don't think that is the problem. I was in the middle of using it when it felt like something gave. As for going with a bigger tool. I was thinking of getting an angle grinder, but wanted to know if I could get away with what I have. As for the bandsaw, I was thinking about it, but I don't have the room for it right now. Perhaps I will get an angle grinder. It is the cheapest solution, and I can also use it to do the final grinding to shape.
