So you think they should just manifest some like they were Harry Potter. Smart.That is too bad Spyderco can't sacrifice a little profit to help you out. As much as they talk about shiny footprints and all.
I think you'll find that a pruning saw is in no way similar to a serrated knife blade. A pruning saw blade is quite thin and flexible, will bend and kink easily and will snap off if too much twisting force is applied. The saw teeth are designed to cut wood, not cloth or any other fibrous material. They will shred, pull and clog with many types of cloth. In addition, many of the good pruning saws are designed to cut in one direction. All of my Silky blades are pull cut, trying to force a push cut usually ends up bending the blade. Also, its quite hard if not impossible to sharpen some of those saw blades. Some are just hardened saw steel and can be touched up with a feather file, but the better ones that are impulse hardened and you can't do much with them.There are a few possibilities there. Thanks for the advise!
Sure. Just show up with a dumptruck full of money.Is it possible to request a bulk order from a knife maker or machinist if you need a mass number of blades?
They're not really there and not in the quantity they need for this project.A simple Google search netted a couple for sale.
Weird.I think you'll find that a pruning saw is in no way similar to a serrated knife blade. A pruning saw blade is quite thin and flexible, will bend and kink easily and will snap off if too much twisting force is applied. The saw teeth are designed to cut wood, not cloth or any other fibrous material. They will shred, pull and clog with many types of cloth. In addition, many of the good pruning saws are designed to cut in one direction. All of my Silky blades are pull cut, trying to force a push cut usually ends up bending the blade. Also, its quite hard if not impossible to sharpen some of those saw blades. Some are just hardened saw steel and can be touched up with a feather file, but the better ones that are impulse hardened and you can't do much with them.
Not really all that weird if you think about it. The blades are very thin, and doing a push cut can easily bend the blade. I thought it was odd at first too, but when you actually pay attention to the rhythm of the cut you realize you are actually not cutting much at all anyway on the push stroke, especially on a long saw like a Sugoi or a Hayate. You don't want to break a blade on a Hayate either, as they are very expensive....If you ever used a two man cross cut you know how this works....Two people, one on each end, each pulling in opposite directions to make the cut. One guy pulls but the other doesn't push, he just hangs on when the saw is pulled. Pushing absolutely flexes the blade and slows or stops the cut.Weird.
All, and I do mean all of the pole saws I use have feature triangular teeth that cut on the push and the draw. Just lucky out here I guess.
Like I said weird. Never had to fix a blade that an employee broke but had to fix a lot of poles they wrecked. Maybe it's a unique to my hemisphere problem.Not really all that weird if you think about it. The blades are very thin, and doing a push cut can easily bend the blade. I thought it was odd at first too, but when you actually pay attention to the rhythm of the cut you realize you are actually not cutting much at all anyway on the push stroke, especially on a long saw like a Sugoi or a Hayate. You don't want to break a blade on a Hayate either, as they are very expensive....If you ever used a two man cross cut you know how this works....Two people, one on each end, each pulling in opposite directions to make the cut. One guy pulls but the other doesn't push, he just hangs on when the saw is pulled. Pushing absolutely flexes the blade and slows or stops the cut.
How do they get the blades they have now? Do they pull them out of thin air? Or do they purchase them with a department budget?Sure. Just show up with a dumptruck full of money.
That's something these guys probably don't have though.
Some people live in places where they never have to think about pruning tall trees. I'm in a Temperate Humid area with lots of big fir, pine, cedar and hemlock but less than an hour's drive you're in hot sandy places with rattlers and nothing but sagebrush. I wouldn't have any idea how folks in Florida deal with the vegetation there.How do they get the blades they have now? Do they pull them out of thin air? Or do they purchase them with a department budget?
Are they required to buy their own?
The Whale Rescue is made of H1 steel and has no handle. There are makers here who sell beautifully crafted knives with handles and sheaths for less than what the Whale Rescue retails for. Who's to say something like that couldn't be made with a more cost effective tool steel for a lower price?
I'm just saying. If the solution is a pruning saw why didn't OP just go to the hardware store?
