3.5" and worn outside the shirt, it wouldn't get in the way at all and most people would think it's a necklace.
I can totally relate to the "because it's legal and I can" motivation. That's what has led me to automatic knives and (soon) double-edged knives. OK HB 1159 needs to freaking pass already so I can take a Counter Tac 1 to work and cut tape / straps / rope / cardboard with a freaking dagger.
Every once in a while, you have to indulge your inner mall ninja. It's just so satisfying and fun to do all those things that you recall wanting to do but couldn't "until you are older".
I'm pushing 30 and I unashamedly admit to having the occasional daydream better befitting to a 13-year-old holding a wooden sword.
I'd wager the OP knows best what he needs based on the requirements of his specific situation and personal experience. If the OP says that boot carry serves him best, I'd say that he's in the best position to make that determination.
If I wore my boots on the outside of my pant legs rather than inside, I would add a boot knife to my daily carry.
Nice rig Charlie_K, good ingenuity, particularly with the quick-release hooks and ring.
I would prefer rigid. I'm no expert in physics, but I believe that movement creates more movement (loosening), as well as creating greater stress on any connections (sheath/boot, sheath/knife).Sweet knife you've got there, but again, I'd be back to trying to figure a way to secure it to my boot.
Which brings me another question I've been trying to figure out. Just how secure should a boot knife be when riding on the outside of the boot? Should he remain rigidly in place and not move? Or is some degree of movement acceptable so it doesn't remain rigid and pressed up against your leg?
Just walking around can cause a boot knife to swing/sway back and forth. And while it might be just a little, it might cause loosening that can result in either the knife exiting the sheath, or the sheath from disconnecting from the boot. I would want the sheath to be attached as tightly as possible to the boot, and for the knife to be secured in the sheath in such a way that it requires a concentrated effort to pull it free.
Okay. I've gotten some great replies on options for knives to take the place of my Kobun, thanks for those. I've also gotten some good questions, like what type of boots am I going to be trying to mate to the knife I get.
I came up with an idea for a possible solution to the issue. Since I can't get the Kobun to clip onto the cuff of my work boots due to the padding, I've taken the clip out of the equation, and I'm simply using the stabilizing harness to keep it in place.
It's fairly stable. There's some degree of back and forth movement to contend with since it's secured in the middle rather than at the top and bottom, but the design prevents the sheath from either slipping up or down once it's clipped onto place. Whether or not the forward and rearward wiggle is a problem, is something I simply don't know yet. But it's comfortable to wear as it doesn't poke me in the leg.
Sorry, paracord and boot knife beginner here. What did you put on the paracord that goes under the boot?
I assume it's for protection?
I have one. It's very light, and has a very thin blade (with a VERY thin tip). The rubber-over-plastic handle is very grippy.What about the Kershaw 4007 as an alternative?
The clip on the sheath is weak, but the sheath retention of the knife is very strong (at least on mine). Trying to pull the knife from the sheath will pull the clip out of a boot or belt. Of course if other means of securing the sheath are used then that might not be a problem.
I don't really like the knife due to the thin blade. But I saw a youtube video where a guy repeatedly stabbed through a car tire with one and only bent the tip a little. I was pretty impressed that it didn't break. Still, I prefer thicker blades.
And I guess I should mention that my favorite boot knife is the United Cutlery "Undercover". It's been discontinued, that's why I didn't recommend it earlier, and the sheath is crappy. I do think that some are still available.
I never gave United Cutlery much regard for quality. Maybe I need to reevaluate that position.
Nope.
Mine is double-edged. I never heard of a single-edged one. I can only assume it's a factory mistake.Did yours come double edged? Mine didn't.
The sheath holds the knife securely, and a conscious effort is needed to pull the knife free. When I inserted the sheath/knife into my waistband and hooked the clip over my belt (thick leather), the entire thing came out of my waistband when I pulled on the knife. The sheath cleared my waistband, but the knife stayed securely in the sheath.Meaning either a conscious effort to break the hold with your thumb like the BK2, or using the mounting points for securing it to the boot.
If that's the guy that was also throwing the Kershaw at the tire, then yep, that's him. I was also impressed by his throwing skills.Skallagrim. He's been a source of a lot of information for me so far. Although because of his recent car accident he's been taking it easy while he recovers.
Many people discount United Cutlery, but a fact that has been discussed on this forum many times is- sometimes cheap knives can surprise you and be of decent quality, and be very useful.I think I know which one you're talking about. I never gave United Cutlery much regard for quality. Maybe I need to reevaluate that position.
