I don't think anyone was talking about profiling on the mill. He was just setting his shoulders square which a mill is great for.
One more word of advice for milling shoulders like you were attempting. When you plunge cut with a center cutting endmill, especially an HSS endmill, it will wobble and flex as you cut. Meaning a .25 em will cut an over size hole. So if you're going to plunge in at your shoulder radii, and then mill out, start away from where your shoulder about .020 or .030". Plunge in, mill your slots, then feed up to where your shoulder is going to be and mill back towards your radius. If I started .030 away, I would mill that shoulder in 3 steps. The first plunge and rough cut, then a .025" depth side cut, and a .005" finish side cut. Do this on both sides and you will have nice straight flat shoulders that lie in the same plane and have a good surface finish.
Oh, if you can, get both sides of the tang to the point where you're going to take the last .005" pass and then feed in your .005", lock the table in the X axis, mill one side of the shoulder, pull the quill up to jump over the tang and mill the other side of the shoulder, without moving the table. That will get you the best coplanar relationship especially on an older machine.
