According to the electrical code I learned.
The maximum continuous load on a rated circuit is 80%
This means on a 110 V 15 amp circuit, you have 12.0 amps maximum
Of the motors you linked to, they are all switchable between 110 & 220 based upon the wires you use on hookup (diagram inside the plate)
The largest motor I have found to fit a standard circuit is a 1 HP 3400rpm at 12.0 amps
(not 1725 rpm, it draws too much)
However if you have to install anyway, 110v larger than 15 amps, or 220
As has been said 220 is better.
220 single phase is almost every home everywhere (electric clothes dryer, kitchen stove....)
Inside the box you pick off one red and one black
You will need:
Empty space in the breaker box
Breaker single for 110, double for 220
Wire suited for the purpose
(ask electrician about the gauge - needs to know length of wire from the box & load Amps
Additional length requires heavier wire, keep it shorter = cheaper)
switch ( make sure its rated for the motor )
Optional outlet & plug, or hardwire it directly to motor. Outlet & plug = $ & convenience
All the motors on your link are capacitor start.
The capacitor is under the rounded cover on the top.
(Removable and movable if needed to fit your grinder)
It stores a charge and provides surge power on startup to improve starting under load
(Not a big startup load on a grinder compared to a water pump...)
Unless you stay at 1 hp or less you will need to spend $ on hookup.
The bee grinder (Canadian square wheel) comes standard with 1 HP 3400 rpm.
I can slow it down if I try & lean into it.
I would go with the 1 hp 3400 and stepped pulleys to allow SLOWER speeds.
This would increase your torque and controllability at low speeds and allow you to maintain the ability to plug it in anywhere you find an outlet.
On the other hand, if you know you want higher HP, go big
The difference from one to the other is very small now compared to changing up later and having to buy 2 motors & redo the hookup twice
First pick the HP you want and then figure out what you need to hook it up.
Steve
