Need Help choosing a small fixed blade to take when I run
I like the izula, especially with the clip plate. It's secure on your waistband and the coating will prevent rust as long as you dry it off after rainy jogs. It also works well as a neck knife even when running. You can't go wrong with ESEE quality.
How about using Tuf-Cloth on an Izula? Like CWL said too, the Salt line from Spyerco, or there is an interceptor from Tops if you like that brand. I had a sheath made by Rivercity sheaths once, and it rocked! Hmm, ESEE 3 is on my list too, ooh, and someone was talking about an ESEE 6 in stainless the other day, so maybe the others will be offered in stainless? it may be worth checking into.
The only other think like I have done is go to Knife Center and set it to search fixed blades, then just set your size limit in the back of your head and check out all the specs, I like that site, because of all the diversity and search functions.
Edit: the new ESEE blades I see on their site show that a couple of them are uncoated. I also just read this while I was on the ESEE site:
"Our knives are made from high carbon 1095 steel. And while 1095 is a top choice for professional cutlery designed for hard use, it will rust and stain if not properly cared for - especially on the cutting edge and around the laser engraving. It is the user's responsibility to keep the blades properly lubricated and cleaned. We suggest using a dry film rust inhibitor such as TUF-GLIDE or TUF-CLOTH."
I agree with the Spyderco Enuff. I have the warncliff model and it is enough for my fixed blade edc.
