- Jun 14, 2012
I am reshaping an old machete that I was going to throw away. I thought it would be interesting to try and make it into a nice looking knife, and if I succeeded I would buy a slab of good steel and make myself a nice little fixed blade. I only used two tools this whole time, a dremel and a hand grinder. I know I had to have messed up the heat treatment, but this is just a practice knife. I used the grinder to do all the major shaping, and the dremel to do the more detailed work. When I got the machete it was a long, black (well what little finish had remained), rusted, rectangle with a broken handle that was sharpened on one side. And from the foot of the blade to the middle of the blade was bent inwards, like a recurve, from abuse. So I cut off the old broken handle and reshaped the curved part of the blade into a makeshift handle, which is where I'm at right now, and where I'm stuck. I also stripped the old coating and rust off to bare metal. And I reshaped the tip into a modified bowie. I really love the look of my homemade fixed blade, so I want to get as much advice as possible so I can take another stab at it. I know I probably need some better tools, but I'm working with what I have at the moment. I do plan on getting a bench grinder and maybe a hand held belt sander (I don't have room for a bigger one), so any advice on what tools I need to invest in to get the job done RIGHT will be appreciated.
First Question: I have a couple of ideas for the handle... First idea is G10, but I've never worked with G10 before and don't know how to shape it properly. Could I use my dremel for this or do I need a different tool? My fall back plan is to simply paracord wrap it, which I am okay with, but I would rather try G10 first.
Second Question: I am pretty sure that I screwed up the heat treat on this knife, but how can I avoid this on my next knife? When I used my grinder I would try to keep the steel cool, I had a cut of water that I would splash on the blade ever few seconds, but the blade still showed discoloration. Are there better tools for reshaping the steel? I would also love some advice on how to regrind (?) this knife and my next would be great. I would like to make this one a full flat grind, or try, but I'm not sure if I can do this with a hand grinder.
Third Question: I have no idea what the blade steel is on this knife, but if I did screw up the heat treat on my next project, is there any way to fix it?
Fourth Question: What steel would be best for a beginner like me to use on my next project? And what thickness would be best for a 10 - 13 inch fixed blade?
Last Question: I am planning on sending out my knife for Heat Treatment and for a Kydex Sheath... Who would you recommend for these jobs?
I would just like to say thank you to any knifemaker reading this and trying to help me out. This project has really made me admire you guys that do this on a more routine basis. I just thought this would be a fun and interesting experience, and a way to Make the exact knife I want to use. So far this project has frustrated me, intimidated me, burned the hell outta me, made me get stitches, made me see potential in something I almost threw away, excited me (when I finally got the shape I wanted), and made me smile till it hurt. I can't wait to finish my practice knife and start on my next carry knife.
