- Oct 19, 2011
Ok, here are the details. This is Aldo's 1084. I sanded the blade to a very clean 1200x. I used Nick Wheeler's method from his old etching video and applied the etchant to the blade using a blue shop towel wrapped around a well washed plastic stick secured with a rubber band. The etchant was heated in a stainless tray on a hot plate with dish soap. I did 4 cycles with white vinegar and 4 cycles with lemon juice. I kept the applicator moving. Both sides got equal wetness and exposure. I removed the oxides with 1500x loose abrasive mixed with 3 in 1 oil applied to a felt pad mounted to a pine block. I cleaned everything meticulously beforehand and was very careful to keep contaminants away from the operation. When I got into the etch and polish cycles I started noticing what looked like scratches in the blade. I wasn't expecting a W2-like hamon with 1084. The overall look of the pattern is not the question. If you notice in the photo, the boundaries of the clouds look like they are being dragged side to side. It would be like putting paint on a surface then dragging across it with a dry brush. So my question is why am I getting this particular phenomenon? It's almost like the acid traveled along the micro scratches in the finish and etched along the grooves. But The blade was well saturated and the agitation was constant. This is my first attempt at a hamon so all the supplies I used were new and clean. Will attempting to sand out these striations wipe out whatever hamon is there?
I guess as long as I have your attention I might as well ask, what am I missing as far as getting more darks/better contrast? Can you scrub too hard when removing oxides? I didn't scrub that hard but maybe you have to be delicate about it?
