- Mar 12, 2009
ok so i have ordered some 1095 steel and im getting ready to make my first knife but i cant decide what type of grind i should do for the main bevel. should i do a hollow grind or a partial or full flat grind or what spyderco calls a HAMAGURI grind here is a quote from their site about the hamaguri "Japanese for "clam" or "clamshell," it describes a blade ground with convex radiused bevels. Also called an Appleseed or Moran grind, it is often produced by grinding on a slack grinding belt."
here are some of the tools i have
-bench top 6" grinder
-1"x30" belt sander (harbor freight)
-1/2" drill press with a mill style x,y axis adjustable vice which allows me to slowly move the piece with a turn of the handle while the press is running. I was thinking if i put a grinding type bit in the chuck this would allow me to keep the blade alligned perfectly while i grind the bevel. i have no clue if this would work or not its just an idea i had
-wire feed welder
-oxy-acetylene torch
-dremel tool
-4.5" angle grinder
-bench top band saw
im not against buying some tools if i need them. I have been thinking about buying an 8" benchtop grinder that i can set up for paper wheels to use for sharpening. I think an 8" grinder would come in handy if i decide to do a hollow grind. im also not sure if an 8" wheel would be large enough to get a proper hollow grind
so any recommendations on what style would be the easiest to do for my first knife would be greatly appreciated. I would like to do a full flat grind but i dont know if i can with my belt grinder since the belt will flex and prevent me from achieving a perfectly flat surface and im not sure if there is a way to obtain a flat area of the belt that i can grind a full flat grind. I was thinking of holding a flat piece of metal or wood behind the belt which i think would give me a pretty decent flat surface.
what type of sander or grinder would a good choice to do a partial or full flat grind on a knife?
the knife im planning on is a small hunter with a 3" blade that will be very similar in shape to a benchmade hunt 15008 except mine will be made of a thinner stock
-wire feed welder
-dremel tool
-4.5" angle grinder
-bench top band saw
