- Feb 24, 2000
Yesterday I got some flat bars of 52100 steel from Aldo. Today I ground out a blade, (stock removal) and in my Paragon oven heated it up to 1650 for ten minutes, , took out and let it turn black, heated it up to 1550 for ten minutes, took out and let it turn black, heated it up to 1450 for ten minutes, took out and let it turn black. Then heated up to 1475 for ten minutes and edge quenched in 130 degree Texaco type A oil .
The Blade did not harden. A file easily cut it.
I Reheated to 1475 for ten minutes and quenched it in 130 degree Brownells Tough Quench . It did not harden, a file easily cut it.
I reheated to 1475 for ten minutes and quenched it in room temperature Parks 50. It did not harden.
I reheated to 1475 for ten minutes and quenched it in water. It did not harden.
After the Water quench, I cleaned up the blade and checked it on my RC hardness tester. It tested a RC of 52. I checked my tester with a CPM 154cm blade that I got back from Paul Bos heat treating and the 154 blade tested a RC of 60, which is what it should be. I think my RC tester is accurate.
So, I can think of a couple of reasons. 1. Maybe my Paragon oven is reading wrong and I need to try heating to maybe 1500 on my oven instead of the 1475. 2. Maybe I don't have 52100. I really doubt that, I have gotten lots of steel from Aldo and it has always been labeled right.
Maybe There is something else I need to try.
