- Feb 1, 2001
Ok I'm at my wits end and need some help! I'm getting into knife making and I bought a Northridge grinder which is about 80-100lbs?. I built a steel pedestal thinking it would be perfect for mounting my grinder to. The darn thing rocks back an forth bad which is unacceptable as the grinder needs to be solid and can't move or it will mess up my grind lines. The bottom plate is 3/16" but it warped. I got that issue fixed but now the center tube flexes under the weight of the grinder and sways when I push into the grinder. I spent 2 full days(working through lots of issues) and $160 on the project and I have to scrap it as it is just not ridged enough to support the grinder properly. I'm already WAY over my budget and cant afford to buy all new steel.
I think I'll have to build a wood table to mount it to. It needs to be SOLID and put the grinder platform so my arms are 90 degrees out like in the picture. I also need it to be portable so how could I mount wheels to is so I can move it around but still be solid and not move at all when using it? It seems like such an easy job but it is kicking my ass and I'm at my wits end with the darn thing! Any ideas would be extremely helpful! Also how does the height where my arms are going to be grinding look? Am I to high or to low? Thanks!
Here is what I ended up with and still stuck back at zero:
