If it's a Wharncliffe then it's going to have a thin tip. If you don't want a thin tip then make a different type knife like a spear/drop point. Anybody else? Am I wrong? A thin tip is part of the geometry of that knife. You can't keep the tip thick and get the edge thin at the same time.
it's all about pressure and the amount of time you spend at each part of the blade. you need to drag the tip ALL the way across the belt. if that makes the grind at the tip go farther up than you want use less pressure as the tip comes across.
I've found that I need to subtly rotate the blade as I get towards the tip to get the thinness at the edge without taking the spine to nothing as well. And I have to do that primarily with pressure towards the edge so it blends without creating another bevel. With a Wharncliffe or a Sandoku like is mentioned above lend themselves to thin tips.
Metal working is not something that comes to you over night. Sometimes there are things that you are going to have to put time in and find out what works for you. What works for one person might not for another. I just started grinding knives as well. I started by grinding metal scrap instead of my shaped knife blanks....
