i peen the pins also, especially in bolsters. i use alot of exotic woods, such as desert ironwood, cocobolo, and ebony, these will crack easily if you peen them to tightly, so drill out the holes a little large, and contersink into the wood. just a little bit. i use stainless steel for pins, becuase they don't bend as easily as nickle silver. for bolsters, i epoxy the bolsters with the pins in the holes, but i don't peen them while the epoxy is setting up. i wait until' it dries to peen them. i suggest using metal bond epoxy for bolster attaching, it dries quick and is flexible enough so you can peen the pins afterward without worrying about breaking the seal.
