Most of us have to "compensate" for the fact that we have "two" hands and arms. If your right hand dominate, that will be the easiest side and less of a challenge in giving you the results your looking for. It takes some time for your body to adjust, bringing the non dominate side up to the level of the other. Its somewhat like learning to write with your off hand.
If your getting a push up, on the grind line on one side, adjust your technique. As mentioned above make contact with the belt farther along the bevel towards the tip; then move toward the plunge. Nothing says you have to grind all the way to the plunge. Your controlling the grind. A blade that is going to have distal taper is much easier to grind if you grind in the distal taper "before" the bevels are ground. Doing this eliminates the need to remove different amounts of steel along the bevel. Using a file guide will even the plunge lines but will do little for the height of the grind lines; thats about belt pressure at the right spot on the bevel.
From the first time the blade blank touches the belt, "keep the grind lines even and equal side to side. Its much easier to do this than it is to correct it later on in the grind. Check out the videos on the Bubble Jig site, theres a lot of useful information on this subject.
Happy grinding, Fred
