need help with drill bits
I am a newbie knife maker cutting up old skil saw blades. for knife blanks and I was told to get carbide drill bits..are they the same carbide drill bits at the local hardware store..I know they have them for masonry..or is there a better style for drilling hard steels like old skill saw blades?..any input would be appreciated.
bill
I would think that you would want to try using a colbat bit or else a good quality HSS drill bit. Availible at most decent hardware stores.
as far as i understand, carbide is referd to as the coating/material of the bits which lets them cut through materials easier. the cut of the drill bit is the other thing you need to look at. im not to keen on the bit shapes but most of them explain them selves on the packaging.
-matt
Masonry bits will work. They're probably your best bet for now. Solid carbide bits might be a little more accurate, but they're expensive and prone to shattering. The masonry bits are much more forgiving, just have to use lots of coolant so you don't melt the tip off.
Cobalt and high speed steel might make one or two holes in a saw blade, but aren't likely to do much more than that. Personally, I've never found cobalt bits to be worth the extra cost. High speed steel bits are cheap, and can be resharpened easily on a bench grinder.
Carbide bits actually have a carbide cutting edge. Its not a coating. Same idea as router bits, or machine tooling. Solid carbide bits are made for machine tool applications and will drill very well, but shatter easily. Masonry bits are steel shank with a carbide tip brazed on. They work just fine for pin holes and are a lot cheaper.
To be honest though, I recommend spending a couple bucks on a peice of O1 barstock that is annealed, rather than spending money on fancy drill bits. It will be much easier to work with and heat treating isn't that big a deal. A saw blade would still probably require heat treating to work as a knife blade, and you don't even know what steel you are using with it.
bill
Is the steel Annealed?
I have found that it really helps me if I can get the steel Annealed first before I attempt to drill in it.
A while ago I had a full-tang knife that I wanted to drill in the handle, but I forget to do this before the heat-treatments so the whole handle was just as hard as the blade.
It was very , VERY hard to drill, and I burned many drill bits before someone on the forum told me to soften the tang with a O/A torch first.
I ONLY use the Colbolt drill bits. I learned about them from a DVD by Wally Hayes.
Watch e-bay, I have found tremendous buys on tooling there. I don't us HSS bits any more. M0st things I will use cobalt, if it is hard I will use solid cardide bits. Carbide dagger bits I find especially usefull for kinfe making.
Leon Pugh
