Need help with my first knife in 1095 steel
ok so ive practiced a bunch with cheap low carbon home depot type steel. (i know thats not a knife steel, i just wanted to practice on something cheap)
so for my first knife i would really like to do it in 1095, I dont own any knives in this steel and i have wanted one for a while so i figured this is a perfect opportunity.
well before i get started i wanted to make sure i have everything planned out, the last thing i want to do is do a ton of work and not be able to finish the knife because i couldnt get it heat treated.
Ive dont lots of looking around on this forum and google and I havent been able to find someone that will do one or two blades for a steel like 1095. I can only find companies that will do air quenchable steels like 440c, D2, ect. I have had no luck finding someone to do the oil quenchable steels on a small order. I have only found people that charge per batch instead of per blade, so i would have to pay the same for 1 blade as i would for 20 and I am not going to have enough knives to make the cost per blade reasonable.
I really want to try a plain carbon steel knife. is there a carbon steel that is air hard-enable?
I will switch to a different steel if i absolutely have to be like i said i would really prefer not to.
is there a forum sponsor that will do small orders of 1095 knives?
If i do have to switch steel, what would be a good steel for a first time maker? I want to make a small hunter or caper style knife that i will use at work (restaurant) and while camping and outdoor activities in general. Toughness isnt important as it wont see hard use and neither is corrosion resistance since i live in a dry climate. I wont be forging the blade, I will use grinders and files to shape the blade. Im planning to have a 3.5" blade, but no larger than 3.75. I would also prefer it to be on the thin side around .100"-.125". I want to give this knife a very sharp thin blade/edge, overall sharpness is more important than toughness
any help with the questions i asked (or forgot to ask) would be greatly appreciated
Their are a couple of guys in the for sale forum that do single blades. 1084 and 15n20 are both easy to home heat treat. What would you be useing to do your heat treat?
If you want to do your own heat treating, 1084 is THE steel to start out with. It is a GREAT steel, just a few points less carbon than 1095. 1095 can be difficult to heat treat, and there are some serious makers out there who refuse to even mess with 1095. You have to have good temperature control, a way to soak the steel, and a fast quench medium.
If you are sending the blade out for heat treat, Peter's heat treating will do 1095. But one blade will cost you $25. You can do up to 20 knives for a total of $110, I believe it is.
If you don't want to use Peter's, and need an air hardening steel, A2 is a great carbon steel and is not expensive by any means.
I'll offer to heat treat your 1095 for you, if you would like. PM me or send an email. I have a kiln and fast quench oil.
samuraistuart@yahoo.com
thank you, i sent you an email.
another question i have is, do i try to put a sharp edge on it or should i leave it on the dull side prior to heat treatment?
