- May 30, 2017
Ok I have another question. I have heated and quenched an 01 tool steel knife then tempered once at 400 degrees for 2 hours. Blade turned out good, but my question is can I now heat treat and quench handle then temper knife again or will the overlap of heating affect knife. The reason I want to do this is after temper I stuck blade in vise and flexed to make sure it would spring back and it did but the handle bent a bit up by ricasso. Ideally I would have a kiln to heat entire knife but I'm doing it on the cheap with little firebrick forge.
