- Jun 11, 2010
Can I use one of these Baldor motors to run my Bader B2 grinder with a VFD? I know 5 hp is a bit much, but the price is right. Are there any disadvantages?
Here are the specs:
AC Motors | General Purpose |
Specifications: VM3613T
CATALOG NUMBER: VM3613T
FL AMPS: 12.6-11.6/5.8
208V AMPS: --
BEARING-DRIVE-END: 6206
BEARING-OPP-DRIVE-END: 6205
DESIGN CODE: B
DOE-CODE: 010A
FL EFFICIENCY: 87.5
ENCLOSURE: TEFC
FRAME: 184TC
HERTZ: 60
INSULATION-CLASS: F
KVA-CODE: K
SPEED [rpm]: 3450
OUTPUT [hp]: 5
PHASE: 3
POWER-FACTOR: 93
RATING: 40C AMB-CONT
SERIAL-NUMBER: --
SERVICE FACTOR: 1.15
SPEC. NUMBER: 36A003T850H1
VOLTAGE: 208-230/460
Here are the specs:
208V AMPS: --
DESIGN CODE: B
DOE-CODE: 010A
FL EFFICIENCY: 87.5
ENCLOSURE: TEFC
FRAME: 184TC
HERTZ: 60
INSULATION-CLASS: F
KVA-CODE: K
SPEED [rpm]: 3450
OUTPUT [hp]: 5
PHASE: 3
POWER-FACTOR: 93
SERIAL-NUMBER: --
