- Feb 17, 2007
I have a piece of damascus that has been ground to .152, but I would like it to be about .08 so I can make some folder blades. The blades I want to make need to be .072. I don't mind some sanding on a granite plate, but not that much and still expect them to come out flat and parallel. The piece is 1" wide and 12" long. If I can get to .08 I will profile, drill and ream pivot hole then harden and temper then grind bevels and then sand on plate to remove decarb and achieve correct thickness on flats. Ya, they are going to be replacement blades for kit folders, but, a guy has to start somewhere on folders. A surface grinder is in my future but not until after new house is complete and shop add on. Things in the shop are crowded now.
On a side note, I have done this before by hand and noticed that after the HT the pivot hole shrunk a bit and the pivot would not fit until I reworked hole with a diamond file. How do you avoid this? I am OK with touching up the lock notch with diamond files, but I don't think a file is the way to go for a "perfect" pivot hole which is key to smooth action and keeping blade aligned.
