- Oct 21, 2006
So this may sound like a dumb question... it certainly sounds that way to me when I read it myself. But... I'm seeking some serious advice from some of you experienced makers out there with a lot of knives under your belt. I've now been into bladesmithing for just about two and a half years, but in that time have only finished 12 blades. Far too few to consider myself anything but a seasoned beginner, and so few that I struggle with "basic" things. For example this last week I cracked and destroyed a nice set of figured cocobola scales that I was putting on a blade when putting the pins through. Chalk it up to inexperience. Right now I try my best on each blade to do the best that my current skill will allow, but i'm taking almost 10 weeks or so per blade, given my normal free time to work in my shop and whatnot.
So my question is, should I, for the immediate time being, lower my own personal expectations and produce a much larger number of lesser finish / not as good as I 'could' do blades of various styles with various handle types untill I've made a few dozen more finished knives to gain experience faster with various techniques like soldering bolsters and guards, fitting pins and the like, and then once i've made and learned from the 'newbie' mistakes, go back to doing the best i can? Or should I stick to my glacially slow pace (exacerbated by the time it takes to fix the mistakes that I'm making due to inexperience) and keep doing the best I can on each new blade and just deal with the problems as they arise?
With the handle scale problem for example, I know what I did wrong now, after the fact, that caused the scale to split. And i'm redoing the handle currently using the method that Stacy posted a few weeks ago in response to someone else's question, because I see the order of steps that he uses minimize the risk of cracking scales due to a slightly too tight pin hole. I'd probably have run into this problem much much sooner if I were "pumping out" a number of blades, instead of just trying to finish this one knife before the NCCA show this next weekend (and getting set back almost a week in the process by my mistakes)
Anyhow, if you can share your perspectives and advice, I would greatly appreciate it.
-Justin
-Justin
