Need some Casio G-shock help
I have a G-shock that I took in for a new battery. Now I can't get audible alarms, all it does is flash instead of beep. What did I do wrong?
Copfish,
I can't say for certain, but some watches have a little strap(and I mean a tiny strip of metal) that goes across or under the battery and is needed for the sounds to occur. When I changed a battery on a Timex the strap went missing and until it was replaced, no sound.
Here's some Casio support numbers:G-Shock watch sales locations LIVE SUPPORT 888-294-7462
Product catalogs, product brochures, instruction manuals. LIVE SUPPORT 9:00AM-5:00PM E.S.T.Mon-Fri 973-252-7570
and here's a site to download a manual, but you need the model #:
http://www.casio.co.jp/pdf/index_e.html
Good luck with it....
Also, I read somewhere that when changing a battery in some Casio watches, that there is some sort of contact with a pair of metal tweezers to something inside that HAS to be made, in order to get things started. That could be the problem?
I had a similar problem w/ a Timex Ironman - battery changed - no sound, but everything else worked fine. Customer support wote back very quickly - the back was on wrong (turned 180 degrees). There is a small diaphragm on the inside of the watch back that has to contact a small spring inside to produce the sound. Turned the back the right way, alarms work just fine now.
Sam
