- Jan 3, 2011
I have completed one knife from start to finish now and was on my second blade. Its a rather thin blade of Aldos 1084. It got a little hot in places during initial grinding. I wasnt sure where to start in the heat treating process. So I just went right to anneal. I used this here im sure most of you recognize Cashens info. http://www.knivesby.com/knifemaking-Kevin-Cashen-treating-1084.html
So im the heat treating oven at 1500 soaked for 10 minutes, cool with the oven slowly.
The blade came out in a slight "S" curve. I then heated with a torch and spent the last two hours banging it somewhat flat on the anvil. Did I completely pooch this one ? What do i do with it from here ?
I think it warped because it was too thin (guessing) its flat enough now I could correct it with a little grinding so long as it doesnt warp anymore.
Im thinking of... Normalize three times then anneal... Harden at 1500 and quench. Following Cashens instructions to the letter this time. Then draw the hardness back by soaking at 400 degrees for ten minutes x three. Being such a thin blade I have a feeling it will warp even worse along the way. Im just not sure where lol.
